How to change the IPD from a Unity App
Hello all,
I am trying to change the ipd from a Unity App that is running on my HoloLens.
Currently I am only able to change the ipd from a remote PC. It works over WLAN with the "https://192.168.0.101" IP and also via USB and https://127.0.0.1:10080.
On my Hololens I am using the same code. I tried connecting to https://127.0.0.1 and https://127.0.0.1:10080 and to the devie IP. Also I am using UnityWebRequest and have checked InternetClient ,InternetClientServer Capabilities in Unity.
In Visual Studio I get the following Output: "Cannot connect to destination host" while it is running perfectly on the remote PC.
I also tried switching off SSL in the HoloLens device portal. In this scenario I used http instead of https. Again, from the PC it works fine but on the HoloLens I get the same error.
This is the script I am currently using for testing:
Thanks in advance!
using System.Collections;
using System.Net;
using UnityEngine;
using UnityEngine.Networking;
public class HttpPostRequest : MonoBehaviour {
private string CsrfToken = ""; public string url = "https://192.168.0.101"; public string path = "/api/holographic/os/settings/ipd"; public string username; public string password; private string urlOptions = "ipd=70000"; private void Start() { InvokeRepeating("test", 3.0f, 3.0f); } void test() { int rand = Random.Range(50000, 80000); DoHTTPPost("ipd=" + rand); } public void DoHTTPPost(string urlOptions) { this.urlOptions = urlOptions; StartCoroutine(SendAuthRequest()); } IEnumerator SendAuthRequest() { UnityWebRequest request = UnityWebRequest.Get(url); request.SetRequestHeader("Authorization", "Basic " + System.Convert.ToBase64String( System.Text.Encoding.ASCII.GetBytes("username:password"))); yield return request.Send(); if (request.error != null) { Debug.Log("There was an error sending request to " + request.url + " : " + request.error + " " + request.isError); } else { CsrfToken = request.GetResponseHeader("Set-Cookie"); Debug.Log(request.GetResponseHeader("Set-Cookie")); StartCoroutine(SendIPDChangePost()); } } IEnumerator SendIPDChangePost() { UnityWebRequest request = UnityWebRequest.Post(url + path + "?" + urlOptions,""); Debug.Log("PostRequestUrl: " + request.url); request.SetRequestHeader("cookie", CsrfToken); request.SetRequestHeader("X-Requested-With" , "XMLHttpRequest"); request.SetRequestHeader("Authorization", "Basic " + System.Convert.ToBase64String( System.Text.Encoding.ASCII.GetBytes("username:password"))); request.SetRequestHeader("x-csrf-token", CsrfToken.Replace("CSRF-Token=", "")); yield return request.Send(); if(request.error != null) { Debug.Log("Error: " + request.error); } else { Debug.Log("Request Success"); } }
DavidKlineMS mod
Applications you write in Unity are UWP applications and are subject to network isolation. What this essentially means is that applications are not allowed to connect to the loopback address.
What is the scenario for which you are trying to set the IPD from the HoloLens? If it is for demos, you may find a tool such as Windows Mixed Reality Commander to be a good solution.
David5 -
Maybe have a look at the FitBoxIPD app source code:
@HoloLee,
David
https://github.com/jbienzms/HoloTools/tree/master/FitBoxIPD
Thanks a lot for the fast response!
In our scenario we will have a server nearby. We will try next to ask the server for setting the IPD from outside.
Thanks! I will have a look at the FitBoxIPD Application.
Thanks for the plug @mGravitus. @HoloLee I wrote the FitBoxIPD above. There is unfortunately no UWP API to set the IPD so I had to talk to Device Portal. As @DavidKlineMS points out, you will not be able to deploy an app that uses this approach into the store because only sideloaded applications can do network loopback. Once they're published to the store loopback is not allowed.
I'm hoping they add a managed API for this at some point in the future, but I don't have access to the roadmap.
Our Holographic world is here
Hi. Any updates on a possible availability of this API? Thx
