Materials in HoloToolkit Purple/Pink
After importing the HoloToolkit v1.5.5.0 into my HTP Install of Unity (Version 5.4.0f3-HTP) my materials are all showing in a purple'ish colour. Replacing it by another texture works fine but it should work out of the box.
Have I imported a wrong version for my Unityversion or is something wrong with my Unityinstall?
Many thank, René
    trzytrzy ✭✭✭
    This probably means your materials were unlinked from their objects somehow. Check your prefabs to see if the materials are null. Unity uses a garish magenta color when there is no material set.
    As @trzy mentioned, that loud magenta color is what Unity uses when it can't find the path to a material. Usually this means it was moved and the path was not updated. You should be able to just reattach the material from it's current location
    I looked around a bit and found out that it was not the material but its shader. Every shader I checked that once you apply it has this purple material.
    I reimported the package to see if something got wrong on the import. But this hasn't fixed it. Applying a third party wireframeshader does the trick and it becomes visible. I'm still wondering though why every holotoolkit shader is purple...
    Many thanks, René
    @Jesse_McCulloch said:
    @René: I imagine that most of the issues you are seeing is because version 1.5.5.0 is upgraded to work with Unity 5.5, and is not compatible with 5.4.x
    If you want a 5.4 compatible version, you need to download the 1.5.4.0 release of the HTK.
    See the release notes here: https://github.com/Microsoft/HoloToolkit-Unity/releases
    Thanks for the info, I'll try that first thing tomorrow and report back if it worked or not.
    best regards, René
