Materials in HoloToolkit Purple/Pink
After importing the HoloToolkit v1.5.5.0 into my HTP Install of Unity (Version 5.4.0f3-HTP) my materials are all showing in a purple'ish colour. Replacing it by another texture works fine but it should work out of the box.
Have I imported a wrong version for my Unityversion or is something wrong with my Unityinstall?
Many thank, René
OptionsJesse_McCulloch admin
@René: I imagine that most of the issues you are seeing is because version 1.5.5.0 is upgraded to work with Unity 5.5, and is not compatible with 5.4.x
If you want a 5.4 compatible version, you need to download the 1.5.4.0 release of the HTK.
See the release notes here: https://github.com/Microsoft/HoloToolkit-Unity/releases
6
Bart
http://trzy.org
As @trzy mentioned, that loud magenta color is what Unity uses when it can't find the path to a material. Usually this means it was moved and the path was not updated. You should be able to just reattach the material from it's current location
I looked around a bit and found out that it was not the material but its shader. Every shader I checked that once you apply it has this purple material.
I reimported the package to see if something got wrong on the import. But this hasn't fixed it. Applying a third party wireframeshader does the trick and it becomes visible. I'm still wondering though why every holotoolkit shader is purple...
Many thanks, René
Thanks for the info, I'll try that first thing tomorrow and report back if it worked or not.
best regards, René
