'UnityGenerated' does not exist in the namespace 'Unity'
I have been scanning the general Net for answers to this:- Error CS0234. I really think it must be something extremely obvious or my set up is not correct. I recently updated and downloaded some stuff. I am using Unity version 5.5.0b-7 (Personal) to get the use of 'WorldAnchorStore' features. I just downloaded the latest HoloToolkit-Unity and reimported it also. The problem comes when Unity creates an App.cs script which it seems to automatically generate or modify when it launches from Unity using the 'Build Settings/Build' key. This is the problematical code which it creates:-
private void SetupOrientation() { Unity.UnityGenerated.SetupDisplay(); }
What am I doing incorrectly here?
Thank you for that. Yes this was the reason I was confused about the process - this UnityGenerated.cs was missing. I found the answer finally after much prodding. I changed the name of this project and realized that the the name of the solution also changed. However the old name appeared also and it was not clear where the assets were. This is some action I would not recommend people do as the parts to your new named project are also shared with your old one and indeed the .sln file is in the App directory of the old named solution directory. If I choose the NEW .sln name and launch that then everything appears to be ok and this file is included in this build. So I think this clears it up for me.
UnityGenerated.cs is a class that Unity will create for you under UWP\ProjectName
Looks like this error is back again.
You can update App.cs to have a:
using Unity;
and then remove Unity as qualification level on the SetupDisplay() statement:
it happens when you Project end with "Unity" then your root namespace will be a distraction to compiler
for example your root namespace is "FPMV.Unity" (my case now) , compiler cannot find "UnityGenerated" in "FPMV.Unity"
