hold a worldanchor when updating an application
I am developing using UNITY 5.5.2f1.
I fixed the object using worldanchor.
Although the object is displayed correctly even after rebooting,
If you modify the application and transfer it from VisualStudio, the object will not be displayed.
Is there a way to keep the worldanchor even if I update the application?
stepan_stulov ✭✭✭
Hello, @hys73
This is not really updating, this is re-deploying of the application. Re-deploying kills the anchors within the application's world anchor store. I'm not sure whether actual updates delivered via the Windows Store will also clear the anchor store. What you can certainly do is store your anchors in a WorldAnchorTransferBatch instead and save that batch file in a location unaffected by the updating or re-deploying processes.
Hello, @hys73
