Room Concept required
Hello All,
I'm working on some concept applications for HoloLens, and I'm wondering if I specifically need to work in the context of a "Room" for where Holograms go. Is it possible to place holograms based on other information, and work with an open concept like being outside?
Thanks
john
CoreyGoff admin
At the core, it seems like you're looking for more details on spatial mapping... Have you had a chance to check out the documentation yet?
It should be. For example if you design everything so that it renders in a radius from the user (with the user being 0,0 on a grid) then it should just travel wherever the user goes.
