How do you copy/paste text while browsing?
I'm using Edge to browse, and I wanted to copy some text to tweet. How can I copy text?? I can highlight the text, but can't find any option to copy it. I paired a Bluetooth keyboard but no luck with Ctrl+C there either. Edge doesn't have an Edit menu that i can find with a keyboard either. Cortana is useless and just searches for "copy text, copy clipboard, copy text to clipboard, etc..) I must be missing something very obvious because this is the last thing I would have expected to be a challenge this morning.
same here, I'm trying to copy a loooong access code to my institution's wifi so i can work without being bumped off, but i can't "copy" the key from my email to "paste it to the wifi settings
Same issue for me too.
In Formation, Inc.
In Formation, Inc.
I have a keyboard, Edge is ignoring ctrl+c though.
Same problem.
Another way would be to use the File Portal via PC --> "Virtual Input"
Its 2018 may 30! Still no copy and paste support for the holo lens edge browser.
Sure does not make it easy to do any work. I have to re type everything.
