Hololens and Beacons
I was wondering if anyone had tried to use beacons with the Hololens ? I can't seem to find a definitive answer as to whether it will work or not . Thanks .
    MattFedoCSGMattFedoCSG ✭✭
    Answer ✓
    Ok so here is the breakdown.
    1) Find and download the .NET 4 Windows.Devices.Bluetooth DLL
    2) In Unity, create the Assets > Plugins > WSA folder and place that DLL in it. When you check the import settings of this DLL, it can be set to 'Any Platform' and it will say 'Native' as the Type, which is fine.
    3) Next, add the DLL I attached to this comment to the Assets > Plugins folder. When you check the import settings of this DLL, you can check it just for WSAPlayer, SDK = UWP, Scripting = Dot Net, and you will see it Managed as a 4.x assembly.
    4) So lets look at some code on the Unity side now. Everything you do to "reference" the DLL, you are going to need to wrap in #if !UNITY_EDITOR because you dont want it to compile.
    #if !UNITY_EDITOR
    using HoloBeaconScanner;
    #endif
    Next under Start() on your script we can place:
    #if !UNITY_EDITOR
            Scanner beaconScanner = new Scanner();
            Scanner.ScannedBeaconEventHandler += BeaconFound;
            beaconScanner.StartScanning();
    #endif
    There is also a .StopScanning() function if you make your var global.
    And once you are scanning you can just set the even handler to catch that Beacon info:
     public void BeaconFound(string str)
            try
                char[] delimiterChars = { '*' };
                string[] components = str.Split(delimiterChars, StringSplitOptions.RemoveEmptyEntries);
                if (components[1] != "0")
                    Debug.Log("[BEACON DETECTOR] : FOUND : " + str.ToString());
            catch(Exception ex)
                //Log error or something else.
    So the beacon data comes back as a delimited string. I will update it with a JSON package, but right now it is delimited by a *.
    Components are as follows:
    0 = UUID
    1 = Major
    2 = Minor
    3 = TxPower
    4 = Raw Signal Strength in DBm
    If the Holo does not find a beacon or encounters an error, it will return:
    0000000-0000-0000-0000-0000000000000000
    So keep that in mind, and hence why I check for Component 1 to be 0 and ignore it.
    I hope this helps someone out there and hope it keeps advancing the Hololens Experience! I will try to keep the DLL up to date! Thanks!
    @Hannah
    Have you find any solutions?
    No not yet . I may look into buying some and trying them out . @Ankit09_Sangani
    @Hannah
    Thanks for quick response.
    have you try this
    https://github.com/andijakl/universal-beacon
    I tried but always Beacon List Count 0 :(
    @Ankit09_Sangani hi - that repository is for UWP only. Did you create a stub for the DLL for Unity editor ?
    You should be able to set the import settings on the DLL to Windows and then set don't compile. You will be able to access the Dll that way. I will give it a go today and see what happens. Holo is UWP btw.
    I got it working. DLLs coming.
    Answer ✓
    #if !UNITY_EDITOR
    #endif
    #if !UNITY_EDITOR
    #endif
            try
            catch(Exception ex)
    0 = UUID
    1 = Major
    2 = Minor
    3 = TxPower
    #if !UNITY_EDITOR
    #endif
    #if !UNITY_EDITOR
    #endif
            try
            catch(Exception ex)
    0 = UUID
    1 = Major
    2 = Minor
    3 = TxPower
    Thanks !! I cant wait to try this out !
    Hello!
    Where can I find the Windows.Devices.Bluetooth Dll?
    Thanks.
    kartikkartik
    edited July 2019
    @MattFedoCSG I tried it but still not working with hololens 1. Can you please share the code or unity project, I urgently need it for my project.
