HoloToolkit Sharing - How can I create persistent session from client?
I'm creating HoloToolkit Sharing Service session from C# console application.
Following is the Main function code:
using (XToolsApp xToolsApp = new XToolsApp())
Timer timer = new Timer(60);
timer.Elapsed += (source, e) => { xToolsApp.Update(); };
timer.Start();
NetworkConnectionData networkConnectionData = new NetworkConnectionData(xToolsApp) { UserName = "TEST_USER", ServerAddress = "localhost:20602", ViewerAddress = "localhost:20603" }; xToolsApp.SessionManagerListener.SessionAdded += (session) => { if (session.GetName().GetString().Equals("Default", StringComparison.OrdinalIgnoreCase)) { xToolsApp.CreateSession("TEST_SESSION", SessionType.PERSISTENT); } }; Console.ReadLine(); }
In above code, the statement "xToolsApp.CreateSession("TEST_SESSION", SessionType.PERSISTENT);" calls the following function.
public bool CreateSession(string sessionName, SessionType sessionType)
XString nameXString = new XString(sessionName);
LogWriteLine("Creating Session " + sessionName);
if (!this.SessionManager.CreateSession(nameXString, sessionType))
LogWriteLine("Failed to request a new session!");
return false;
return true;
Further, in above code, the statement "this.SessionManager.CreateSession(nameXString, sessionType)" calls the following function, part of HoloToolkit.Sharing namespace's auto generated SessionManager.cs class
public virtual bool CreateSession(XString sessionName, SessionType type) {
bool ret = SharingClientPINVOKE.SessionManager_CreateSession__SWIG_1(swigCPtr, XString.getCPtr(sessionName), (int)type);
return ret;
But it is still creating ADHOC session (not PERSISTENT). What should I do to create PERSISTENT session?
@GurpreetSingh,
Have you filed an issue in the HoloToolkit-Unity GitHub repository? I highly recommend reporting issues there so the community working on the HoloToolkit is directly made aware of and address the problems you are seeing.
David
