Using WorldAnchorStore in Unity Editor
I was trying this out in the unity editor, but for some reason WorldAnchorStore.GetAsync(AnchorStoreReady); never completes.
Is there not a way to get the WorldAnchorStore in the Unity Editor?
For clarification, I'm playing the vanilla sharing scene from the Unity Editor with the sharing service running locally, after setting a break point in ImportExportAnchorManager.cs in the AnchorStoreReady GetAsyncDelegate method.
Stephen Hodgson
HoloToolkit-Unity Moderator
Patrick mod
Probably not. Unity would need to do something to emulate anchors in the editor.
Anchors are stored relative to positions in the real world. Since you don't have access to the real world inside of Unity, it's going to be very tough to get anchors to work in that environment.
The documentation for the sharing kit Tests says 3. Either click "Play" in the unity editor or Deploy to device. This implies it should work in editor, as well as on device.
I've also worked on other projects while at Microsoft where we were able to play in editor and see remote users as well. I wasn't involved in that aspect of the project (nor have access to it any longer), but it could be doable, or at the very least faked, or I could just be completely off base on how it was achieved. haha.
Stephen Hodgson
In the editor the sharing scene effectively treats the anchor as the scene origin.
Okay, so then is
ever supposed to get an anchor store while playing in editor?Stephen Hodgson
I had the same issue. One way around it would be to implement unities scriptable objects to save Anchor points at runtime in the editor.
