How to make a character actually sit on your real chair using Spatial Understanding in Holotoolkit.?
I have been working with Spatial Understanding in HoloToolKit, I have a 3D model of a human sitting and it is animated, I used "Shape Queries" and was successful in placing the 3D model on anything that is similar to a chair like "Sittable" or "chair", but the 3D model appears above the chair, it's legs are placed on the chair, where as it's legs should be hanging on floor and the 3D model should be sitting on chair.
How am I suppose to make the 3D model appear sitting while it's legs hangs down the chair..!
similar to this video https://www.youtube.com/watch?v=iUmTi3_Ynus
at 2:24 - 2:30.
Like in Fragments, where the lady sits on the couch and her legs hangs down to the floor.
any help will be much appreciated.
stepan_stulov ✭✭✭
If the sittable position is determined correctly (place a tiny red sphere there and check) then it seems like a pivot problem of your human mesh. The human should be with her, erm, ass at Y zero in order to sit tightly when placed onto the sittable surface.
5 -
trzy ✭✭✭Note that Spatial Understanding includes a query for platform *edge* positions that you could presumably use. I haven't used object recognition yet but there is probably a simple way to constrain queries to surfaces on the objects. If you can identify a "platform edge", you would place your model there. But, as @stepan_stulov said, you need to make sure the object pivot point makes sense.
For a sitting character and a position right at the edge of the sittable area, the pivot should be below the gluteal muscles, between the hamstrings (i.e., just below the butt, between the back side of the upper legs, when thinking about a standing pose character).Bart
http://trzy.org1
Bart
http://trzy.org
Thanks @stepan_stulov .... I will check that..!
@trzy .... I will try to apply the 3D model for the "Edge" platform and but have to set the pivot first I think
