Keeping object coordinates stored after scene restart
wml
Hello!
I have the following setup:
- Spatial Mapping and all other managers are loaded from in a "setup" scene together with DontDestroyOnLoad()
- Main scene where an object appears at a specific position.
At the end of the scene the following should happen:
- Store position of object (Object needs to reset itself so I can't use DontDestroyOnLoad())
- Restart scene
- Apply old positions of object
- Object should move to corresponding position
What happens after the restart:
- Object move somewhere else
All spatial mappings and other manages are loaded in a different "setup" scene and kept in memory via DontDestroyOnLoad()
What should I do to prevent this and that I can place the object at the proper position after the scene restart?
Try to use World anchor.
This should be happening because hololens create a new coordinate system when the new scene load.5
