How do I enable the Remote System Capability for a Unity HoloLens App?
I made a new project in Unity. I'm using 5.5.2f1 Personal.
I added a Cube to my scene.
I created a NewBehaviorScript and added it to my Cube.
My NewBehaviorScript is this:
public class NewBehaviourScript : MonoBehaviour { // Use this for initialization void Start () { #if WINDOWS_UWP var accessStatus = System.WindowsRuntimeSystemExtensions.AsTask(Windows.System.RemoteSystems.RemoteSystem.RequestAccessAsync()).Result; Debug.Log(accessStatus); #endif } }
Under Build Settings I picked Windows Store. I selected Universal 10 for the SDK. I selected D3D for the UWP Build Type. I selected 10.0.14393.0 for the UWP SDK. I checked Unity C# Projects.
Once I build in Unity, I open the Package.appxmanifest in Visual Studio. I check Remote System under Capabilities and save.
When I run the application in Visual Studio using Remote Machine to my HoloLens, the following is printed to the console:
DeniedBySystem
If I do something similar to NewBehaviourScript inside a new Blank Universal App and enable the Remote System Capability, I get Allowed, instead of DeniedBySystem. For some reason it won't work on a Unity HoloLens App. How do I enable the Remote System Capability for a Unity HoloLens App?
Try in Unity to go on the tab "HoloToolkit" --> Configure --> Apply HoloLens Capabilities Settings.
this can be the "Internet Client" capability.
I tried what you said:
The Remote System capability ended up being checked:
However it's still saying DeniedBySystem
Maybe there's something I have to enable on the HoloLens for Apps to use the Remote System Capability?
You need to check SpatialPerception as well in those capabilities.
I tried checking Spatial Perception in the list and I'm still getting DeniedBySystem.
Sorry, I didn't look closely at where the error was occurring. Not sure why unity doesn't have remoteSystem listed as a capacity. That makes me wonder if it is not supported. But I do not know that by any means.
