HoloConsole
Hi! We've been developing the HoloConsole Project. It allows you to check how is your application doing in realtime. https://www.youtube.com/watch?v=hdPxtNTAJhI&t=17s
However, the Thermal API doesn't seem to work, everytime is consulted it responds 0, when the values are 1,2 and 3. Have someone used it yet?
OptionsDavidKlineMS mod
@Drosquete,
It appears that the Windows Device Portal API documentation is incorrect. The values should be 0 == Normal, 1 == Warm, 2 == Critical.These are the values that the WindowsDevicePortalWrapper project expects from the REST API.
I will work to get the documentation updated.
David5
@Drosquete,
David
@DavidKlineMS Thank you a lot!!! :-) I can update the information in the HoloConsole then
