Spatial Anchors without Spatial Mapping?
Can spatial anchors be used without spatial mapping? I have a fairly large area which I dont really need to map. However when I place my objects they tend to drift a lot. So I'm thinking of using spatial anchors in WorldAnchorManager just to prevent the drift. I don;t need these anchors to persist between app sessions. Can this be done?
OptionsReeley ✭✭✭
Yes you can! Although you will still experience drifting when having a large distance to an anchored object.
5 -
OptionsJesse_McCulloch admin
The recommendation to prevent drift is to not place items further than 3 meters from their anchor. So one approach is to anchor an empty game object close to where you will be placing items, then placing the actual objects in relation to the anchor gameobject. You can do this as many times as you want, so that you can avoid having items a long way away from an anchor.
