problem installing the VS 2015 update 3/ HoloLens Emulator
Hello all. I have a problem installing the VS 2015 / HoloLens Emulator. While downloading VS 2015 update 3 (since it is a pre-requisite for HoloLens emulator) an error pops up.
Error says:
This product requires Microsoft Visual Studio 2015 with Update 1 and UWP tools versions 1.2
Can someone help me to download Visual studio 2015 update 3. I will highly appreciate a stepwise solution. (I use windows 10 and do not have older version of VS 2015)
1
I face the same issue. Were you able to fix it?
having the same issue, no solution found yet. They make it seem like it is so easy to get started but the set up is the most confusing part!
