Unity Poor Perfomance on Demo Scenes
Hello,
I'm pretty new to HoloLens development and I'm facing some basic issues with Unity3D. (V.5.6.1f1)
I started off by following the provided guides by Microsoft on how to create and deploy unity scenes for the HoloLens. I'm currently working on the Holograms 210 Gaze demo project and I'm fighting with a very poor rendering perfomance. I tried to match all the settings they do in their videos, but I'm not getting above 10 - 20fps which is horrible.
Can anyone guide me a bit so I get a perfomance around the 60fps goal? Are there some special settings I have to be careful with? My render settings are on fastest and the rendering is set to 16-bit depth. The app I want to build after this will have around 30-40k tris and does not need reflections or shadows (unlit shader). Thanks for any help!
Optionscre8ivepark ✭✭
@binloan Are you using Master or Release for the build? Typically Debug build is quite slow.
5 -
Optionsbinloan ✭
@trzy said:
Debug/Release is set in Visual Studio. You should see it up top.
Also, make sure your Quality settings in Unity are set to Fastest. If you are unsure, go to Edit -> Project Settings -> Quality and then post a screenshot here.The release settings helped a lot and made at least 10fps more. Also my .fbx
consisted out of many sub-objects. This created a huge draw call number in Unity which then caused my lag. By melting as much parts as possible I reduced my draw calls from around 80 to 15. At that moment everything went buttery smooth. Thanks for all your suggestions.0
http://typeinsight.org/hololens
Out of curiosity is HDR enabled on the Main Camera? If so, disable it.
Bart
http://trzy.org
Where do you set this? Inside Unity or after the build inside Visual Studio?
I have to check that, but as I used the demo scene for testing I "hope" they had set it up properly... I will report back.
So I checked back, HDR is disabled on the camera. Any other suggestions? I'm running the GameControllerManipulatorTest scene from the holotoolkit and on my pc it has a rendering time of around 1.2ms with 2 batches and 292 tris. Same problem on the hololens...
Bart
http://trzy.org
