DEP0001: Unexpected Error: -2147024809 (HoloLens Emulator)
Quant3D
I have a Unity/C# application designed for Universal Windows Platform.
When I convert the program to the HoloLens, everything compiles but I get this error in deployment to the HoloLens emulator:
Deploying to Phone Internal Storage… Creating a new clean layout… Copying files: Total 90 mb to layout… Checking whether required frameworks are installed… Registering the application to run from layout… DEP0001: Unexpected Error: -2147024809 ============== Build: 3 succeeded, 0 failed, 0 up-to-date, 0 skipped =============== ============== Deploy: 0 succeeded, 1 failed, 0 skipped ===============
The same error appears whether I try to install with the Debug/x86 setting or the Release/x86 setting. I have uninstalled and re-installed the HoloLens emulator multiple times.
I am able to get the program to run, but it would be nice if Visual Studio would point to the area that is giving the error.
1
When you say convert are you just picking Hololens as the target in Build settings?
Did you try wiping the deployment folder? It may still have some old properties in there.
