SharingService Server Trouble
Well. I am trying to set up sharing service with Holotoolkit. However, one problem is that my SharingService.exe can never run properly.
I only changed the Precompiled Header Memory Limit to "/Zm200" for "ClientUniversal". Otherwise, the building failed due to "Compiler Error C3859: virtual memory range for PCH exceeded". At the end of building, somehow the building window closed automatically. Then, neither can SharingService.exe be found in Command Prompt nor can it execute properly by clicking .exe file. Other SDK .exe files seem work fine. Just wondering what is going wrong with my building?
Thanks for the help
I have the exact same problem as you, did anybody find a solution?
Thanks
Not a complete solution, but have you tried using the pre-built sharing service? https://github.com/Microsoft/HoloToolkit-Unity/tree/master/External/HoloToolkit/Sharing/Server
