Isolate ToolsController
Hi guys!
First of all I find the application amazing! I think it also really cool that it is completely open-sourced!
Since it works so smooth, I would like to isolate the ToolsController Prefab and import it to my projects. But I am having trouble overriding the project-specific objects like the planets.
I have exported an asset from Unity with the ToolsController Prefab and all its dependencies but it seems that the controller is so interwinded that I cannot get it to work outside the Galaxy Explorer Project.
Any ideas? Is there a way around this problem at all or not?
Thank you in advance!
Michael
    Hi Michael,
    Were you able to use the toolbar outside the project?
    I am looking for the same solution.
    Thanks
    Vineet
    Unfortunately I have not worked on that issue since my previous post.
    Cheers
    Michael
