Relationship between Sharing Service, HoloToolkit and Spectator View
Hello, everybody.
I'm slowly approaching implementing Spectator View and would like to know the high level relationship between the Sharing feature, HoloToolkit and Spectator View.
Whats uses what? Whats depends on what? What can be used independently?
This question is not about code but about concepts.
Cheers,
    james_ashleyjames_ashley ✭✭✭✭
    Answer ✓
    For instance if you wrote your own socket layer to sync up behavior between different hololenses -- I don't think you would need the HoloToolkit in that case. You still need the components from the HoloLensCompanionKit, though, which manages the details of the compositing.
    edited June 2017
    Hey, @james_ashley
    Thanks a lot for your explanation.
    Hypothetically you could probably use your own sharing mechanism, in which case you wouldn't need the HoloToolkit.
    Could you please elaborate on this point? Would I still need some part of the HoloToolkit to run the Spectator View even though we have our custom sharing mechanism?
    Answer ✓
