Relationship between Sharing Service, HoloToolkit and Spectator View
Hello, everybody.
I'm slowly approaching implementing Spectator View and would like to know the high level relationship between the Sharing feature, HoloToolkit and Spectator View.
Whats uses what? Whats depends on what? What can be used independently?
This question is not about code but about concepts.
Cheers,
james_ashley ✭✭✭✭
(As I understand it) Spectator View uses the sharing feature to sync up what is happening in the HoloLens you are filming with the HoloLens in your SV rig. You have to decide what messages you are sending back and forth and what info you actually want shared. It also means getting the import/export sharing manager working. Sharing in turn depends on the HoloToolkit.
The set up for Spectator View sends your DSLR capture to a PC and composites it with your shared experience, also running on the PC, based on your calibration file.
So SV -> Sharing -> Toolkit.
Hypothetically you could probably use your own sharing mechanism, in which case you wouldn't need the HoloToolkit.
People tend to get distracted by the rig that lets you combine the hololens and the camera. The most important hardware is actually a good internal capture card -- otherwise you face lag issues.
www.imaginativeuniversal.com5 -
james_ashley ✭✭✭✭
For instance if you wrote your own socket layer to sync up behavior between different hololenses -- I don't think you would need the HoloToolkit in that case. You still need the components from the HoloLensCompanionKit, though, which manages the details of the compositing.
www.imaginativeuniversal.com1
Hey, @james_ashley
Thanks a lot for your explanation.
Could you please elaborate on this point? Would I still need some part of the HoloToolkit to run the Spectator View even though we have our custom sharing mechanism?
