holographic tracking state lost
Hi,this is the first post
----------------------------Console---------------------
Assertion failed on expression:'IsMatrixValid(matrix)'
holographic tracking state lost. New State:1
Connected successfully but when I played the scene, all crashed.
The console showed above.
----------------------Configuration---------------------
Unity: 5.6.0f3
I used the Wireless LAN Card to connect the computer and Hololens.
BTW, there is a Javascript on the scene. Show as below.
#pragma strict
function Start (){
function Update(){
transform.Rotate(0,25*Time.deltaTime,0,space.self);
I'm not sure the problem is about Microsoft or Unity.
Thanks for any suggestion.
2017/6/27
I think your code is off but I don't tend to write javascript so perhaps I am wrong.
In C# it would be something along the lines of:
transform.Rotate(Vector3.up*Time.deltaTime,space.self);
Or if you really wanted to expand that Vector then maybe:
transform.Rotate(new Vector3(0,1*Time.deltaTime,0),space.self);
You could replace the 1 with a 25 but that seems like a large amount of rotation. Try this first before ramping it up.
Nevermind, looks like your code is fine. Maybe just try a 1 instead of 25 first.
