Why "out" parameter for "hitInfo" for line 85 of GazeManager for Hologram 210
OptionsReeley ✭✭✭
With out you give the method a reference to your variable. this is needed in this case because a raycast has a return of bool ( if it hit something), but you also want some information about the object you hit. So the method will take this referenced varibale and will fill it with this information.
1
