How to get 3d-points(x, y, z) data of Spatial Mapping Mesh??
Hi, I'm doing some projects for HoloLens
I want to get data for all points of Spatial Mapping Meshes
Does anyone have any idea for this?
Thanks
trzy ✭✭✭
@Buster Sounds like you want to get the mesh data, which will give you all vertices. Assuming you've scanned your space using the SpatialMappingManager, you can get all the mesh filter objects like so:
List< MeshFilter > meshFilters = SpatialMappingManager.Instance.GetMeshFilters();
Then, you can access the mesh or sharedMesh (they will be the same for spatial mapping meshes, although I think accessing sharedMesh will prevent a needless copy from being made by Unity internally) property of each spatial mesh filter:
foreach (MeshFilter meshFilter in meshFilters)
DoSomething(meshFilter.sharedMesh);
}As for how the mesh object itself works, the Unity scripting reference is your friend: https://docs.unity3d.com/ScriptReference/Mesh.html
Long story short, you can simply access the vertices property (which will create a copy of the data for you). This is an array of points (Vector3). Spatial meshes don't have any transforms applied, if I remember correctly, so the points should already be in world space but you might want to check that to be sure.
If you want the raw point cloud from the depth camera, you're out of luck. Meshes is all we're allowed to get.
Bart
http://trzy.org3
The SpatialMapping creates a gameobject for each face found with the naming convention "Surface-" + someId. So you could Find all gameobjects which start with the name "Surface-"
Bart
http://trzy.org
@trzy Thank you for reply. As I checked your reply so late, I'd found to get vertices like you said, use MeshFilter.sharedMesh.vertices
this method can read/write vertices So is what I've been looking for.
Spatial Meshes do indeed have WorldAnchors on them though. If you want to capture and reload them, you will need to save off the world anchor that corresponds to the mesh.
