Anchor App-Start-Position (stage origin)
I want to anchor the start-position of my app. My app is always in the same room, and i want it to be always at the same position and heading in the room. I want to calibrate this position (maybe via bluetooth keyboard). Right now, I have to position myself (the HoloLens) at a very specific position+heading when I start the app. I don't want the user to do this every time and occasionally I get some offsets when the HoloLens rescans parts of the room.
Should I just use spatial anchors or is there a simpler solution to set the stage origin for a given room?
Thank you and best regards,
Hans
rimber ✭
I'm assuming you want to position the objects inside your app in same way every single time.
Best way is to create a root object at origin and use WorldAnchorManager to anchor it. Every time you start the app, load the anchor for the root object. This should do the trick.
I've noticed the offset issue as well. It seems the hololens is rather sensitive about the spatial scanning and orientation of the device. Sometimes my room is 70-80 degrees off! If you notice it, simple restart the device so that it tries to detect your surroundings and hopefully fixes it.
