Charging HoloLens when switched off
Hi all,
is it possible to charge the HoloLens when it's switched off? Mine seems to boot up every time I connect the charger.
Reason: I'd like to charge it with some low-power charger, and when switched on, it drains faster than it is charged with that device...
Regards
Matthias
Just switch it off after you plugged it in
Yes, that seems to work with the original charger, I just tested it. Mine is so weak that the HoloLens repeatingly switches on again. Maybe the voltage drops periodically beyond some limit so it feels like being un- and replugged. I'll get a stronger charger!
