A few basic questions on acer headset
ahalim
Hello MR experts,
Sorry this probably has been asked before but I did read most of the docs and can't seem to find the sure answers:
- it's not mentioned in the acer specs but does it support Bluetooth?
- if Bluetooth is supported then can we use 1) Bluetooth headset (like AirPods) and 2) Bluetooth Xbox controller ?
Jesse_McCulloch admin
The acer is connected to your PC, so the PC is what things like the Xbox controller would pair up to. I assume that the same could be done for headphones too.
6 -
FranklinChen admin
Jesse is right, if you open the MR portal(on your PC) and set up your HMD, the portal will detect your bluetooth for using bluetooth controller
5 -
ahalim ✭✭
Thanks guys. I got it, so the immersive headset is primarily only for display purpose, most of the main processing including the other inputs are done by the PC.
That's correct. the headset is just a display
