Has anyone had any success with TCP or UDP networking?
I need to send information in strings to my device and can't get TCP or UDP working. I am getting errors that previously people are getting when I try to build the app in Unity. I have not found a successful way of doing either of these. Has anyone had any luck?
Hey, @ctowers
If you're using Unity you can try combining NetworkDiscovery for discovering servers, NetworkServer for server side and NetworkClient for the client. This is proven to work, I have successfully built a network application running multiple clients on PC, in the Editor and HoloLens all communicating with a Windows tablet running a server.
@stepan_stulov
Does this use a TCP connection or UDP packets. I am receiving message from a sender and the sender can only send on TCP or UDP.
Can you share some code?
I posted a possible solution here
https://forums.hololens.com/discussion/7980/udp-communication-solved#latest
