How to do navigation/manipulation gestures in immersive controller ?
I wrote a simple test app that can rotate an object via navigation gestures and move and object via manipulation gestures, all in HoloLens.
I would like to port the same app into the immersive environment, but don't know the equivalent buttons/keys for navigation/manipulation for the motion controller (or the simulated keyboard/xbox controller).
(Note: as an example, airtap gesture in HoloLens can be performed via the 'A' button on the xbox controller. But how about tap-and-hold ?)
If anyone knows, please help! Thanks!
Optionsahalim ✭✭
In addition, the holotoolkit (from MR250 project) already has its InputManager processing the bumper+trigger+rightStick as input to navigation event, so this is even better, no need for extra codes and messing around with InteractionManager. You just need to install the navigation handler interface implementation.
The codes work as-is for both hololens and mr.0
Try this page Advanced HoloLens Emulator and Mixed Reality Simulator ... The HoloLens
and the right mouse button held down or the Right or left triggers.
But you will find that the Xbox 360 wired controllers act different to the Xbox One controllers as they have two sets of triggers Right button and right trigger.
Thanks for reply.
The trigger only gives you the hold info. We still need the position/rotation to process the navigation/manipulation. I am guessing it will have to be a combination of trigger and bumper+left-stick or something like this. I will experiment more.
After further experimenting, I finally made it worked. Here is what I did:
(My MR environment is simulated with xbox one controller)
Overall, the app can choose what the button combinations it wants to be used as navigation. Since grip is not possible with the xbox controller, I just decided to use the trigger or A button instead.
