public update in gestures
Why does the AstronautManager.cs of Holograms 211 (Chapter 5 - Model expansion) use a public void Update() method at the end? Why public?
I am a novice, following MS academy tutorials, and so far I cannot understand why this Update function is declared public here, so I would appreciate someone helping me understand.
stepan_stulov ✭✭✭
Hey, @hmiri
Update() is one of the Unity's so called built-in MonoBehaviour messages, or in other words standard methods that Unity engine will call on your scripts if defined. They can be defined with any level of access (public, private, protected) and also whether or not the methods are virtual. Despite being declared as public you don't have to call this method, it will be called by the engine. In some exceptional case you would call this method, but that'd usually be an ugly hack.
I personally declare all MonoBehaviour methods as public without any real reason behind it. Some people prefer private to prevent temptation of calling it by someone else.
I recommend getting familiar with Unity's script life-cycle.
1
Hey, @hmiri
