What is Best Approach Large Object Recognize,Make Virtual Model and Load On Hololens
Hello All,
i have large Machine i want to scan/recognize Large Machine and create virtual model and load in Hololens. i research and found but what is the the best way to do.. ??
I found below things please suggest the best way.
- Manually align virtual model to actual/physical model.
- Via Image Marker which is attached to real world object (via Vuforia toolkit).
- Scan Actual model via generating mesh with HoloLens device.
Please Help Me out this thanks in advanced.
Ankit Sangani
We've used 1. and 2. If you are just doing a single demo where its just a single model and you are running the demo then 1 may be the easiest way to do it.
If you are doing something more complex where there are multiple models or perhaps you won't be running the demo then 2 works well. Just takes longer to develop but actual use of the app should be easier.
I haven't done 3. I heard that vuforia was releasing a CAD scanner down the road. I am not sure how long away that is nor what size model it will support. But if you have a way to pull it off that would be the ideal setup.
Thanks @mark_grossnickle for your prompt response.
@mark_grossnickle pardon me but would it be possible to use the shape recognition in the spatial understanding to create a custom shape, then tell it to create a mesh based on that shape? (I am quite new to coding so unsure if that is feasible)
@AvionicHologram I'm not sure I completely follow. It seems unrelated to this thread. Maybe make a new thread with your question with more details? I'll keep an eye out for it.
@mark_grossnickle Sorry about that, I asked because I thought it would be a way to fulfill @Ankit09_Sangani number 3 condition.
