Stationary Experience
If I wanted to create a stationary experience where I'm not reading in data from the depth sensors, how do I do that?
Optionsstepan_stulov ✭✭✭
Hey, @TetraTalon.
Would you mind elaborating on what you mean by stationary? Do you want the elements of your scenario to be stationary in the world? Then you'd need world anchors to ensure persistence. Those anchors can be added regardless of whether or not you're using spatial mapping (which is a reconstruction of the environment topology which is based on, amongst other things, depth sensor). Traditionally you'd use intersection of gaze and spatial mapping mesh to find a place for your anchor but you can also utilise different techniques that don't rely on spatial mapping. Like simply carrying a hologram in front of you (head-attached) and releasing where needed. This will work without having Spatial Mapping component in your scene at all.
Why are you trying to avoid relying on the depth sensor though? Your environment is very dynamic? If so then I'm afraid world anchors may not work either which a stationary environment may be based on.
Alternatively you can drop using anchors and spatial mapping altogether and rely on other clues like VuMarks from Vuforia.
Bare in mind that not using depth sensor won't deactivate that sensor. HoloLens will still try to "map the surroundings" no matter what. You cannot influence that process except for removing Spaces in the Settings.
Or did I completely misunderstand your question?
Hey, @TetraTalon.
I'm trying to make an app that works outdoors as a proof of concept (although I'm setting a goal of only having it work in one particular area that doesn't change much). Imagine going down a track of land with holograms viewable from a fair distance as you move. I find that I keep running into problems with things drifting, so I'm thinking the depth sensors are getting confused. If I could just use my starting position as an origin and have everything be placed a certain distance from it, that would be great, but whether I simply place them at a relative distance in Unity or use Anchors, there's a fair amount of drifting that takes place.
Now I'm thinking that one possible solution is replacing the depth sensor data with input from a gps to continuously update the position of the hololens, but to do that I obviously need hologram placement to be fully functional even without the typical depth sensors.
I've tried using markers with Vuforia with mixed results (the holograms seemed to be pretty unstable). I'm also trying to allow visibility from a fair distance away, so not sure if it can work with that. Also, don't you need spatial mapping in order to utilize Vuforia?
Hey, @TetraTalon
I'm afraid HoloLens is simply designed with indoors in mind.
@stepan_stulov Yeah, but did you see the video where this guys cuts his bushes with the help of HoloLens? It's hilarious
Unfortunately, yes. Just trying to push things to their conceivable limit
We have been developing a Hololens application for AEC so we have been doing a lot of experimentation in this area (e.g. outside, large inside areas, solving drift issues). Unfortunately, even in the best of environments you will get some Holographic drift and outside you get a lot of drift for example I placed a multi-storey hologram of a building on a bare section - and that was moving around almost continuously.
I don't think integrating a GPS is the best solution as they aren't that accurate, but you might be better off integrating a Lidar device. Then you can position and reposition your Holograms based on the relative position as determined by the Lidar. We haven't done this as yet with our product - but we may do so in the future
Interesting. I guess it's good to hear I'm not the only one experiencing this. We're looking at using Differential GPS to get a more accurate reading. I hadn't even thought of using Lidar. What is the AEC btw?
Architecture, Engineering & Construction
