Anchor an object using the world anchor manager and disallow the user to move it
Is there a way I can world anchor an object but prevent the user from moving it later on?
Amaal ✭
Hey everyone, I added the script Tap On Place on the model I wanted to move, and disabled movement using the keyword manager script on the holotoolkit.
What would cause it to move?
If you had it place an anchor upon finishing moving wouldn't that prevent it from being moved. I thought that once it was placed it couldn't be moved unless a script removed it.
Hey, @AvionicHologram
This thread should clarify the topic definitively:
https://forums.hololens.com/discussion/comment/15033#Comment_15033
ah ok thanks @stepan_stulov
