Room mesh got all messed up
AlexD
After using the HoloLens for about 2 days in an office environment, between multiple rooms we've noticed a weird thing happened to the spatial mesh.
It's almost as if at some point, the HoloLens became confused about orientation and started mapping the room at a different angle.
Attaching a photo of the 3dView page.
Any idea what might have caused it and how to avoid it in the future?
Optionsmmerry ✭
Specifically, if you can, please use the feedback app to file feedback under "Windows Holographic -> Hologram quality, stability and reliability" and choose the "reproduce" option. Look around your environment to where the mesh is incorrect, and this will give us plenty of data to debug the issue.
Thanks
Matt5
I haven't seen that myself. I wonder if you walked over to where the world seems to have tilted if the spatial mapping corrects itself.
Both "worlds" are in the same area of the office. So, I was exactly where the tilted version of it existed before.
Okay, I've sent a query to my friends in spatial mapping. In the meantime, if you want to recreate your map, you can do some from the HoloLens device. From the shell select Settings, and place the settings app somewhere. Then select the 'System' subapplet. In system you'll see a 'Spaces' option on the right hand side. You can select your space and then select remove. A new space should be created automatically, and you shouldn't need to reboot, but I usually do so anyway.
If you see this again after resetting your map let us know.
Hey Patrick,
Yes, I had reset the space using the procedure you mentioned and everything worked. I mostly opened this thread for you guys to investigate. I'll be sure to let you know if it happens again, before I delete the mesh in case you want me to perform additional debug steps.
Thanks.
Awesome, thanks Alex!
The spatial mapping folks got back to me. They requested that if you do see this again to use the Windows Feedback app on the device. The feedback app should give you an opportunity to include the mapping data as part of the submitted feedback.
Thanks
Matt
I had the same Problem. Feedback is sent through feedback app.
@Patrick
Do they need the Spatial mapping File? I could not attach the file to the feedback...
If they do, send me a privat message. I cant upload it here because of size restrictions.
Lukas
