Changing the IPD (InterPupillary distance) before an App starts
I am developing an app that is likely to be used by multiple people on the same HoloLens, so I would like to streamline the process of calibrating the HoloLens before the App starts.
At the moment this is done by requesting the user run the calibration app from the Shell after they put the HoloLens on, however this can be a painful experience as most users have not used a HoloLens before.
Ideally, what I'd like to be able to do is give the user the HoloLens when the calibration app was open, and then after calibration was complete, my app would launch.
I am aware of the Headsetadjustment scene that is part of HoloToolKit-Unity, but this only ensures the user can see the HoloLens's field of view.
Has anyone encountered this problem?
Thanks in Advance!
Jimbohalo10 ✭✭✭
@mHarris said:
And @Jimbohalo10 , would that solution allow the user to measure and set their own IPD? or would it require the assistance of another user?Quote Taken from the Readme.md
KinectIPD
KinectIPD is a utility to measure a person’s IPD (inter-pupillary distance) and optionally set the IPD on a HoloLens device automatically.This is especially useful in situations where many users are using a HoloLens device such as demos or tradeshows. In testing, KinectIPD was accurate to +- 2 millimeters, which should be adequate for most HoloLens scenarios.
The Startup app would first call the IPD software, then call your app. HoloLens can only have one task running at a time.
The setting up of the HoloLens camera is covered in Locatable camera in Unity as an example of using HoloLens as a webcam
You could dig through
https://github.com/jbienzms/HoloTools/tree/master/FitBoxIPD
and merge it with your project. I do not see any reason it cannot be set up to run in the same project so your users go directly from setting their IPD to your application.
Hi @mHarris
Have a look at KinectIPD
This has lots of code which could be used to possibly read and set IPD.
Just replace the Kinect 2 for PC webcam to calls with HoloLens camera.
I have used this originally and though people say it should have special lighting I just opened the curtains and "let the light in"
Thanks @mGravitus and @Jimbohalo10 , both of these seem like they would be useful to me.
With FitBoxIPD, am I right in thinking it is only capable of setting the IPD, and not measuring it?
Hopefully official support gets added for this at some point...
KinectIPD
