Acer headset, blue Square in left eye
I'm seeing a blue Square through my left lens when connected and navigating the cliffhouse, and it doesn't go away no matter what I launch. It's also there during the setup phase, but wasn't during my initial setup. Is anybody else having this issue?
OptionsJesse_McCulloch admin
I would first recommend getting your machine on the Insiders Fast Ring builds. The Mixed Reality Portal is dependent on optimizations being built into the OS level, and there have been significant performance and stability improvements between 15063, which is commonly known as the Creators Update, and the current fast ring build, which is 16257. Almost everyone I have talked to that has been having issues with their headsets has seen them resolved by moving up to the latest insider build.
Let's get some environment info on your side. Please tell us your OS version and Header model version.
About how to get the model version, please follow these steps:
Under the category "Mixed reality devices", right click "Acer Mixed Reality" and click on properties
Click on the "Details" tab at the top, and for the "Property" dropdown, select "Model"
The firmware bundle version is listed under "Value" - in this screenshot, we have A85-B2-2i2.
