HoloLens stuck in starting up
I have a problem with the Hololens. It is always stuck in the starting, the led do scroll from the center outward forever (I need to keep pressed the button for 10 seconds to turn off). The thing is that I did a full device recovery but nothing changes. I cannot do anything with the device.
Any idea what I could do to solve this?
Brean ✭
Also you should create a ticket at Microsoft directly, this is the Developer Forum not the Device Support.
4
Maybe the battery is totally discharged. Try charging the device with a 2A power source for at least 30 minutes.
I tried with the full charge. And I know that maybe this is not the correct place to ask, but I don't saw much information...
Thanks for your comment.
Before i recovered device i was still able to connect to the device portal and pull an error message:
The following services encountered issues: dwm.exe, holoshellapp.exe. If this status persists for more than 1 minute, please reboot the device.
The redlights no longer flicker on the front of headset and holograms cannot be displayed. Lights scroll from the center outward meaning the device is booting.
I've raised a support ticket with Microsoft. Hoping the support team can guide further.
I'll also try recover with any new software versions. With Fall Creators Update around the corner hopefully we won't have to wait long.
I'm having this issue too - @Montagon @Srmnm did either of you get this fixed?
