HoloLens: How do I recover an app's landing page that got overtaken by spatial mapping?
Here's what I mean:
I placed an app's landing page prior to it figuring out the spatial mapping. But now that the spatial mapping is in the way, I can no longer close the app! This has happened to me a few times now. The only workaround that I have found is to uninstall the app completely from the HoloLens and install it again. This would be a pain if I had downloaded this app from the store and had to re-download it.
Is there any way to get to this app and close it without uninstalling it?
Tam
OptionsDocStrange ✭✭
or say "Hey Cortana, Move [app name] here". Also, you can open another window, select to move and every hologram/window will be highlighted to move. You should be able to grab your window or resize it enough to grab the middle.
1
Go to settings and find the room that corresponds to this space. Delete the room data and it will remove all placed apps.
@gjrgj @DocStrange Thanks for the helpful tips! Glad to know there's more than one way to resolve this.
