How to identify if a hologram is in user gaze view in DirectX UWP C# Hololens app?
Akash
I am rendering the scene with some holograms similar to spinning cube renderer. I need to know if a user wearing hololens is looking at them. Most of the suggestions are for Unity. I am using DirectX rendering in C#. Any suggestions?
OptionsAkash ✭
Found the answer.
Thanks to: https://forums.hololens.com/discussion/6785/understand-when-a-user-clicked-gaze-on-particular-object-in-directx-newbieYou need to manually use raycast to get the intersection information. I had to dig up further to get possible raycast libraries to do so. Best one is to use SharpDX.BoundingBox and SharpDX.Ray.
Found the answer.
