Get the full Spatial Mapping in Unity
Hi everyone.
After doing some tests with Spatial Mapping, I came out with the conclusion that with the components provided in ARToolKit, actually only a portion of the space is loaded. More precisely, where the user stands. It is also the same when you try to save the spatial mapping from the 3D View inside the Hololens portal. When clicking on update, only a portion is loaded although the Hololens is aware in which saved space it is. The rest is then loaded as you walk.
My question is whether it is possible to load the full spatial map which is "probably" stored somewhere inside the Hololens.
I actually want to do some spatial processing on a very big space (370MB).
Thank you
There is a way described to obtain the Spatial mesh obj file: https://developer.microsoft.com/en-us/windows/mixed-reality/holograms_230#chapter_1_-_scanning
Maybe this is what you're looking for?
Hi BNJMO,
I'm having the same problem, trying to load a 162M space from 3D view. Have you figured something out to address this problem? Thank you.
