Gestures on HP Mixed reality
I have an HP mixed reality headset, it looks like is working OK, just the display and the mouse. The gestures are not working. I assume the headset video cameras are working and are enabled.
1. How can I verify that the video cameras are working ?
2. How can I enable gestures
Thank you
gjrgj ✭
I don't think the external cameras can be used to record video, and gestures are not supported on this headset.
5 -
Jesse_McCulloch admin
The "cameras" on the HP and Acer are not cameras so to speak, they are used for the tracking of the headset motion. So, yes, they are working, and no, they don't support video capture or gestures.
6
Thank you, most likely you are right.
No gestures? Does that mean no hand tracking at all? Will that be enabled at some point in the future? Can we get access to the depth camera feed to try and use OpenCV or something? This is a very frustrating limitation.
I don't understand why is called Mixed Reality Headset, there is nothing mixed. Is only VR if the cameras are used only for head tracking. That means I can't superimpose VR over real video. If this is correct than I have to return the HP headset, is useless I have better VR headsets.
The reason Microsoft has elected to call this framework 'Mixed Reality' rather than making a distinction between VR and AR is because they are making strong efforts to allow seamless parallel development for both mediums at once. To really understand this, I strongly suggest going through the [Holoacademy 250 - Sharing Mixed Reality] tutorial. It shows how easy it is to develop a single app that runs effectively on both the Hololens and VR headset offerings.
