Accessing Game Objects inside of # IF/ENDIFs
Part of my program has to be inside # If ! UNITY_EDITOR because it uses parts of the Windows API. In this same region of code, I'd like to mess with game objects and modify text. Is this possible? Or can you not do this inside if # IF / ENDIFS? I've tried to do this, but it doesn't seem to work.
Hey, @TetraTalon.
UNITY_EDITOR signifies whether or not you're running your app as an actual build or from within the Editor and in itself has nothing to do with what platform you're developing for (although there are some overlaps).
Check these links for details:
https://forums.hololens.com/discussion/comment/15459#Comment_15459
https://docs.unity3d.com/Manual/PlatformDependentCompilation.html
@stepan_stulov , I've seen other people handle my situation in this same way though (like here: https://forums.hololens.com/discussion/578/hololens-udp-server). I don't need it to be specific to the platform, just need it to compile outside of the editor, but I'm curious if all my traditional Unity methods such as game object manipulation will still work if it's on anything other than a UNITY_EDITOR block.
@TetraTalon
They will work. Basically everything that comes from UnityEngine namespace using will work on every supported Unity platform. In Editor or in the build.
The code I have below doesn't seem to tho. I'm trying to figure out if it's an issue with my connection or what.
`using UnityEngine;
using System;
using System.IO;
if !UNITY_EDITOR
using Windows.Networking.Sockets;
using Windows.Networking;
endif
public class UDPListen : MonoBehaviour
public TextMesh test;
public string port;
public GameObject turn;
//public string word;
public bool rec;
if !UNITY_EDITOR
endif
if !UNITY_EDITOR
endif
Would you mind being more specific to what exactly doesn't work? Are you testing this code in Editor? If so, you have almost no code to test, as most of it is excluded from running there. Literally the only line to execute in Editor is:
And rec variable is always false.
Also
Yes, it's not from UnityEngine namespace, so not sure what you mean with "tho". Would you mind clarifying?
