HP Lens Question
JeffK
I noticed my HP unit that came has a black area underneath the lens on the left eye. This is either an area of dead pixels (black) or dirt or something on the display inside the unit. It's apparent and really annoying.
Does anyone know if you can remove the lenses like on the Rift to get access to the display? I tried (carefully) and while they do rock slightly, I couldn't get them off.
Or should I just contact MS for a replacement? Which I may have to if it is dead pixel(s).
Can you post a photo of it?
