Course 250 - Don't See Avatar or Clue from HoloLens
Hello!
I'm performing Course 250 with 2 HoloLens & 1 HP Headset. When I join the HP to the session I do not see the avatar or the clue from the HoloLens as shown in the videos. Although I am able to teleport around the island using the HP headset.
I've added all 4 UNET Sharing components.
Level Control is enabled. Enable Collaboration is checked.
Any ideas?
    Hi _Spinteractive,
    Do you see the person on the island from the HoloLens devices? Any spew from the debug panel?
    Can you try the completed scene:
    AppPrefabs\Support\ChapterScenes\SharedMixedRealityLand
    and see if that is working?
    edited August 2017
    Hello, thanks for the response!
    No I do not see the person(avatar) from the HoloLens. I used the download files from the Course 250 link at the top. And followed the tutorial. Debug panel spews stuff yes.
    I just tried the completed scene and it also does not show the person in the headset from the HoloLens.
    Any ideas?
    Here's some debug. It says no Avatar at somepoint.
    OK using the completed scene I moved the island away from me and the person/avatar popped up about 10 feet away from the island. (It may have been in the wall so I couldn't see it before). When I move in VR the avatar does not seem to move in HoloLens.
    Welp! Someone fixed this problem. I downloaded the files today and it works as excepted. Must a been a bug. It happens!
    :) I knew waiting a while would work for this one.
