Material changes after LoadScene
Hey everyone,
I'm currently trying to load a scene which has a gameObject with a specific material attached to in it. If I start the scene itself, it works perfectly well and the material can be seen. However, I want to start the game by pressing a button on a menu screen. Therefore, I'm loading the scene with the gameobject after the scene was chosen from the start menu. The problem is: If I start the game this way, the material is somehow lost and my gameobject is just black. This is the code for the Sceneload:
public void Level1()
SceneManager.LoadScene("Spider_baker_2");
public void DemoLevel()
SceneManager.LoadScene("Level_0");
public void EndScene()
SceneManager.UnloadSceneAsync("Menu 3D");
It tried to use Scenemode.Additive, but then another issue occurs, since I can't instantiate more instances of my singleton classes from the menu scene. If I then try to develop it for the HoloLens, the application crashes completey, so I'd rather stay away from the Scenemode.Additive.
Has anyone ever had this issue?
Where is the material in your project Hierarchy? Make sure it is under the Resources folder to be included. Also make sure in your build properties that each of these scenes are checked to be included in the project.
