Mixed Reality 250
I have built the Mixed Reality 250 project, the Acer headset has joined the hololens island session however both headsets cannot see each other.
In addition the hololens cannot join the acer session, only the other way around. The screen becomes black on the hololens.
What am I missing to finish this project?
It’s when the Acer joins there is not interaction between the headsets.
Do you see the clouds hovering the users head?
It does sound like there are some network issues involved. Can you possibly try it on a home network or something like that, were there is less likely to be any sort of port blocking/firewall issues?
if you tap the debug button on the back of the volcano is there any debug spew? (on the immersive device you can use the 'x' button on the Xbox controller to toggle the debug panel, it will be backward since it is on the back of the volcano, and the app literally uses the same model scaled up for immersive. )
When the Acer headset joins the hololens session the debug panel throws a “null reference exception object reference not set to instance of an object”
Any thoughts on why this would be the case ?
if there is a null reference exception, there should be a stack with the script that is referencing null. Usually this means that some parameter in a script that is meant to be set in the scene hasn't been set. Does 'UsLand' have a parent object set on its level control script? If not, MixedRealityLand should be set as the parent.
Which scene are you building? The SharedMixedRealityLand scene is the one I've spent the most time testing.
@BillyGBabs Regarding the null reference exception, you're not missing anything, it is a bug. I submitted a workaround to the git repository for this project last month, but I don't think it was ever fixed. Basically, you need to edit the MixedRealityTeleport.cs script and wrap the Update method to only run on immersive headsets (i.e. IsDisplayOpaque = true). Take a look at the link for more details.
oh, this is the fade script thing? I'll get that fixed.
