An empty project with an OnMouseDown method does not run on the Holo Lens
I have posted a question in the unity forum and a guy there thought it might be a good idea to post here also.
https://forum.unity3d.com/threads/how-can-a-script-that-is-not-used-with-a-method-that-is-empty-create-an-error.488593/#post-3188996
Is this normal that you get a "Screen position out of view frustum" error when you use OnMouseDown in your Holo Lens project?
regards
PS: Maybe this question belongs to the bug area, but it may also be that I just don't have enough knowledge.
We use OnMouseDown in our projects without issue but we are using Unity 5.5
Downgrading may help?
https://stackoverflow.com/questions/43415004/error-running-hololens-unity-project
I'd be surprised if the OnMouseDown was the root cause. Are you using the Holographic camera? Or what is your camera setup?
There is a bug with Unity 2017.2.0b7&8 that the HoloLens just launches into a black screen
