Insider Preview 16275.1000
ahalim
Installing on my other computer now...
BTW, Is this different from the 16275 ?
Does it have the fix for the MRP starting issue ?
It's not any different than 16275. The .1000 is just bringing us closer to the actual Fall Creators Update release numbers. Once they get to a final build for FCU, then if you go off the Insiders Previews, the only number to increase during patch Tuesday updates will be the numbers after the decimal.
Ah bummer! I was expecting the fix for the MRP issues... Thanks for the info Jesse.
