Access network share with the HoloLens
Hello,
I want to write an application that reads some files from a Network share. For that I set up a NAS using the IP 192.168.1.1, and a specific user to access this share.
This is what I tried:
path = @\192.168.1.1\Documents\SharedFiles\;
string userName = @HoloLens;
string userPassword = "HoloLensPassword";
string userHost = "192.168.1.1";
NetworkCredential theNetworkCredential = new NetworkCredential(userName, userPassword); CredentialCache theNetCache = new CredentialCache(); theNetCache.Add(new Uri(path), "Basic", theNetworkCredential); var g = theNetworkCredential.GetCredential(new Uri(path), "Basic"); var tt = CredentialCache.DefaultNetworkCredentials; StorageFolder folder = await StorageFolder.GetFolderFromPathAsync(path); IReadOnlyList<StorageFile> fileList = await folder.GetFilesAsync(); foreach (StorageFile sF in fileList) { textBlock.Text += sF.DisplayName; }
It always says access denied. When i run the app on my Windows-Notebook, the app works on Windows. But it only works if i already logged in into the NAS. Without a previous Login in the NAS it does not work, too. So i think i Need to generate some Credentials on the HoloLens-Device.
I'd like to know if this is the correct way and what is wrong with that code. I searched the Internet for hours to find a solution but i was not successful.
Did you ever fix your problem? I was interested in this as well...
